Totally kooked my oil change today... First I borrowed the worst jack ever, then it was a mission and a half to get the filter off. Well, eventually I had everything back in place.
I had an open oil can showing exactly 3.4 litres on the outside measure. Beautiful, I thought, and poured almost all of it into the motor.
Checking the dipstick I saw that the level was now just at the bend. Maybe a bit on the bend. With no oil in the filter yet I started the motor, expecting the level to drop a little, just where it should sit after a change.
However, the oil level is now still on the upper bend of the dipstick. Sort of in the middle of that bend, I'd say.
If it is just on the bend or very slightly over, and you're sure the car is on a flat surface, engine warmed (but off), etc., when measuring the level, you'll probably be ok - the dipstick is not a precise measuring device by any means (neither are oil cans, as you've discovered!), and the engine is designed to cope with a little variation in 'full'. If it's much higher then that, then the safest option is to open the drain valve and let the excess out - it will not take much to get the level back down again. These are small engines so there's comparatively less wiggle room, and the risk of fouling spark plugs or getting oil in the wrong place is comparatively high (I've also seen one or two mentions of smaller VW engines being more sensitive to overfilling than others, but can't confirm that point).
Not all of the following suggestions are advisable, but they'll give you an idea of the problem:
Question Each time I had my car's oil changed at the dealership, the dipstick showed that the oil level was a quarter of an inch to almost an inch above the "full" level
Routine oil changes are a preventive maintenance item that’s usually performed several times throughout a year. But what happens if you overfill auto oil?
Thanks a lot for this extensive info, very appreciated! Car was perfectly levelled, but not really warm (getting the filter off took ages...) when I measured. Gonna re-check with a fresh head tomorrow and, in case of doubt, open the drain plug ever so slightly to let a bit out.
Mine is just below the curve, but not quite on level ground, not worried.
OVERFILLING is a big no no, blew up a Chrysler Horizon back in the day (anybody remember those). It had a low oil light that wouldn't go out.................. until I overfilled it and blew it up
Definitely. Too much oil and the pressure will force it into places you don't want it to go.
Pro tip: Put some of the recommended amount into the filter before you install it.
Related Threads
Up Owners Club
156.2K posts
16.3K members
Since 2011
