Hi All
Mine is starting to peel off from the left hand side... Has anyone else had this, or is it just my bad luck that some water may have got in to a weak bit of the adhesive?
Cheers
S
I changed it 3 times. The key is to have the car super clean, and make sure you follow the instructions that come with it. Also the temperature. Too cold or wet will ruin it. I did it myself the last time and it worked. Previous times were done by the dealer.
Hmmmm... Maybe I should do it myself next time!!
S
