If your oil pan is too full, oil can get into places where it's not meant to be and be affected by the parts working in that area, which could in turn do harm to the rest of your engine.
Thankfully, you have only barely gone over and it shouldn't do much harm at all.
Driving the car carefully should burn off the oil, it can in cases damage the catalytic converter as too much oil can result in oil entering the combustion chambers.
I'm not a mechanic and could be wrong but this is an observation given you're not bucket loads over
If you have the facilities opening the oil drain plug really quickly will solve your issue
Greetings, my fellow UP owners! Totally kooked my oil change today... First I borrowed the worst jack ever, then it was a mission and a half to get the filter off. Well, eventually I had everything back in place. I had an open oil can showing exactly 3.4 litres on the outside measure...
www.upownersclub.co.uk
Yes, overfilling the engine can damage the engine and anything downstream from the engine, smaller engines have less tolerance for error, and the odds of damage go up the more you've overfilled and the harder you drive the engine. If you look at the dipstick, and see how long the 'ok' range is (hatched area B in the manual's diagramme, p.189), and then consider how much 4mm is in comparison, you'll get an idea of how much extra oil is in there.
I will just ask if by the 'max line' you mean the top of the hatched area (the B/A line) or up onto the bend (beyond A). If you're above the bend it needs to be drained (especially as you have the means to do so), but if you're just on the bend I would still advise draining out the excess for peace of mind.
It's about 4 mm above the top of the hatched mark. I'll have a think. It's using a bit of oil, which was why I topped it up in the first place, so maybe just let it burn off the excess... dunno.
Better to drain than risk the damage. If you can't do it yourself, drop in to Halfords, they'll drain it off and refill to the level (no filter change if you just did it) shouldn't be too painful.............
I would be iffy about driving it . drop the oil out first and don't risk the damage.
Related Threads
Up Owners Club
156.2K posts
16.3K members
Since 2011
