If you whant your own Pois in MM Thats Possible and you can naviage to these POI.
I use it for CNG station in Switzerland.
First you need your Pois or make it your self by Word etc ,look at the MM manual, these Pois musst bee in Comma serapreet value Short CSV.
then connect your mm to the MAC or PC go to thefolder Navigon, in there make a new Folder callMyPOIs (this is importet otherwise it will not Work use Big and Smal Letters !! EXACLY call it MyPOIs)
then you can place your CSV File there i nthe new Folder, you can also put a Icon there, bmp (Bitmap) or png (Portable Network Graphic)
SIZE max. 40x25 Pixel
here some example:
greetings
Jarre
here some example:
greetings
Jarre
