1 - 3 of 3 Posts
I have two annoying problems with my radio:
  1. It states Learn - Safe (or Safe - Learn) now and then. What the heck is this?
  2. I cannot figure out how to set the default channel (it starts on the same channel each time
Anyone?
My radio comes on again exactly on the same settings as previously ( I've left it switched on when ignition key removed),
Are you in the UK? (Your Profile doesn't help much!)
Have you stored
a station on each push button?
Have you set-up the radio 'properly'? (Dealer set-up mine, but I've made
a couple of adjustments) Have you used the AS (auto store) function?
I'm in Norway and the stations were prestored by the dealer. I haven't done anything to the radio other than using it :)
The radio always start on the same station regardless of what station it was listening to before turning the car off.
1 - 3 of 3 Posts
