1 - 15 of 15 Posts
What would happen to ones remote key if it were to be dropped into the toilet bowl mid-flush? Would it die?
It's just, ummm, he really needs to know...
Put in a bowl of uncooked rice overnight.
Then try it in the morning.
it might work.
Don't eat the rice afterwards though.....
My remote key for my last car went through the washing machine on a hot wash, once dried out I never had an issue with it..
Mine (for other car) fell into the fish pond and it is still fine,
I hung it above a radiator, not to close the battery might over heat and leak acid
Not quite the same as your friend but I dropped mine in a deepish puddle and worked alright....So far
what a silly friend of yours
That was good advice then! In this case I would still avoid it after cooking.
only need +62degC to kill bacteria so boiling the rice wud take care of the lil b*ggers anyway
Discussion Starter · #12 ·
The cooking would likely kill the bacteria though, probably. Still. Best leave it eh.
Edit: beaten to it! HahaEdited by: Davec86
If you drop an electronic device in water,get the battery out and put the device in distilled water right away.
Rinse and repeat with fresh distilled water.
Repeat that a few times.
Let it dry somewhere warm - but not hot - so the water evaporates slowly.
Water is not really corrosive and not very conductive, it's the minerals in regular water that will short out and kill electronics.
1 - 15 of 15 Posts
