1 - 13 of 13 Posts
Hi all.
I own a Move Up with Maps + More.
When getting satnav directions,
they play in my speakers, but if I
have the radio on at the same time,
the radio is not muted while the satnav
directions are played. The radio level
stays the same.
Is that normal or have I missed a setting somewhere?
Thanks in advance
Kenneth
I think it's normal, but not sure why! It seems to be the same on mine.
My radio mutes when the sat nav gives directions, it would be a bit rubbish if it didn't! I don't know if there is a setting for this as mine has done it from out of the box.
There is a setting under the satnav options as to level of muting...you can have it mute none, a little or a lot!
M&M options
Here is the link to theDanishversion of the M + M manual.<div style="text-align: left; : rgb251, 251, 253; ">
<div style="text-align: left; : rgb251, 251, 253; ">http://www.navigon.com/portal/common/Download/Manual/PNA/MapsMore/maps_x_more_DK.pdf
<div style="text-align: left; : rgb251, 251, 253; ">And here's a ink to the M + M manual in 24 different European languages.
<div style="text-align: left; : rgb251, 251, 253; ">http://www.navigon.com/portal/int/kundenservice/faq.html?id=21774350&content_identifier=faq&page=1
<div style="text-align: left; : rgb251, 251, 253; ">Nick
NAV > Options > Settings > general
Here are my options in General:
Brightness Day/Night
Display Mode
Direct Access 1/2/3
Volume of the Assistant
Use voice command
Show the time
Time format
Date format
Distance unit
Units of temperature
Coordinate format
Select route profile every time
Input mode for address data
Language
Voice (Susan or Henry)
Keypad layout
None of the above are for mute. Am I missing something ?
Thanks for your help .
Discussion Starter #11
Display Mode
Direct Access 1/2/3
Use voice command
Show the time
Time format
Date format
Distance unit
Coordinate format
Language
Keypad layout
Hi.
I seem to have the same options.
I still can't figure out how to mute the radio when playing satnav directions :-(.
When using the phone it mutes the radio without any problems.
OK, sorry was thinking of the merc system
on the up, when in nav mode, press the direction window (left lower ) to hear the voice and while the voice is playing turn the radio volume control.....radio display will say speech and let you set a volume over the music playing.
Discussion Starter #13
Hi.
Yes, I can do that, but the radio will still play in the background. So I guess it can not be completely muted getting satnav directions, like the radio is, when using the phone functions.....
Best regards,
Kenneth
1 - 13 of 13 Posts
