Hi All, new member here ! I’ve been hearing a very concerning rattle/metallic noise from just under 2000 rpm onwards when in neutral and applying light throttle. It also happens when driving at the same RPM and increase rpm slowly in each gear.. It can be heard quite clearly when your driver...
www.upownersclub.co.uk
There's also one report of a loose rubber bung in plastic trim:
A few weeks ago my 65 plate up started with a rattle noise from what seemed like in the dashboard, sounded like a screw was rattling around in side the dash, at around 2000 revs and 30-40 miles per hour it got louder. I went to VW to find out what was making it happen the tech said the whole...
as well as sycamore seeds falling into the engine bay trim (wrong time of year for those, though):
Hi Guys, I was wondering if any of you have encountered a high ish pitch rattle coming from behind the middle of the dash? Seems like its behind the radio or glove box. I have checked all the loose items in the glove box and cubbys and there is nothing there causing it. It is constant above...
And some pre-2017 facelift ones had problems with the heat shield (not sure if new ones are still suffering):
I have a rattle coming from underneath towards the rear.on the left-hand side looking from the rear on my 3 month old move up.any idea members what's causing it
Also have this problem. Only between 2k and 3k. It’s quite loud. Car has had it a while and performance hasn’t suffered. I’d really like to find out what it is as nothing seems loose.
Related Threads
Up Owners Club
156.2K posts
16.3K members
Since 2011
