The guard comes with tape already fitted. If you open your hatch and look under the the rubber seal that goes around the rear hatch you will see four screws that secure the rear bumper top edge. Basically you take these 4 screws out, slide the bumper protector into place and put the screws back in but don't tighten them up. The bumper protector has screw holes already drilled (and they do all line up). You then peal the backing off the 4m tape that goes up the 2 sides and along the bottom and press the item into place. You can then tighten the bumper screws, job done. The web page did show the fitting instruction I think. In any case it only took mins to fit the item.
