Er, what?Scrubnut said:There is only one, but if I change the bulb so there are two, will I blow a fuse?
I've done it on Audis no problem...I can't believe there will be a problem.Itzben said:Try it and tell us
Scrubnut said:I've done it on Audis no problem...I can't believe there will be a problem.Itzben said:Try it and tell us
If you don't hear from me again, you'll know there was.....
Scrubnut said:There's only one rear fog light. There's a dual filament bulb on one side and a single filament bulb on the other. I just wanted to know what would happen if I had two rfl instead of one?
