1 - 16 of 16 Posts
having had 2 polo's why have VW changed the place where reverse is ??? waiting for my up and haveing done a test drive feel confused why they had to move it ?? any answers please ??
it did confuse me slightly as a fellow VW driver, i had to think a bit extra when putting it into reverse on my test drive too, but like mark points out those new to VW wont notice the difference and the rest of us will get used to it!
The potental problem is that is where sixth gear is on our other vw,so if you get heavy handed it could be nasty.
R1ch said:
That's a good point. Have 6 gears on my Skoda (effectively a VW gearbox). Going to have to be careful. Is reverse selected by pressing down on the gear stick or pulling up?
Reverse gear is across to the right and back, no pushing down or pulling up, so 6 speed boxes may have trouble getting used to it x
In all fairness in recent months I have had nothing but problems with the gearbox in my golf mk4!! (rivet in the final drive went and put a hole in the casing... 750 quid later my car was back on the road!)
I welcome a new gear box with open arms :p
The reverse gear in the Up is the same as my Aygo. My
parents have a polo which has the reverse gear on the opposite side to the Up and
the Aygo. New people coming to VW will not notice the difference.
Is there really nothing to stop you from accidentally putting the car into reverse when going 60/70 mph? For those that are used to 6 gears this had a potential to be very nasty. At least if you had to push down or pull up it would be harder but this doesn't seem
To be the case.
No it is just pull back. I guess the sincro would not let you but at 50-70 a masive scraping noise would not be nice. Plus there was a post on here that a car was taken back because of a dodgy box. I hope they re think and change it do it is safe and works better. There again I think they will as in the first year of production the Fox was changed quite a few times.
Cosmetically they changed the steering wheel
I believe they also had a bit of a mess about with the electrics and a few other underpinnings.
As the first cars that went out had some faults that did not show up in pre launch testing.
Now they have a few hundred/thousand Up!'s on the road these faults will be addressed and things my change from what the first cars came out like, like the Fox.
Edited by: cl coupe
1 - 16 of 16 Posts
