1 - 3 of 3 Posts
Hi, can anyone help me out please. I bought this single din mounting kit from eBay. In order to fit my RMT200 radio bought from my dealer, Robinsons VW, Stamford.
http://www.ebay.co.uk/itm/390801057409?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I've managed to remove the factory fitted radio thanks to instructions how to do so here on the forum which was easier than I thought it would be. In the kit, everything is pretty straight forward reconnection of plugs but there are two wires left over to be connected somewhere else and I'm stumped.
There is a red wire maked 12 volt ignition/switched and a short orange wire marked as illumination dash light. I'm stuck as to where these go, can anyone help me?
Thanking you all in anticipation. Jon.
Hi I cannot download it so cannot help you ,you would be wise to call a dealer ,or take it
To an auto electrician ,they could most probably help, Regards Phill ,
Sounds like a job for a multimeter......clearly one is the switched ignition and the other the dash lighting so should be easy to determine which they connect to with a multimeter on the harness
1 - 3 of 3 Posts
