<!--if gte mso 9>
<w:Word>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:TrackMoves/>
<w:Trackatting/>
<w
unctuationKerning/>
<w:ValidateAgainstSchemas/>
<w
onotPromoteQF/>
<w:LidThemeOther>EN-GB</w:LidThemeOther>
<w:LidThemeAsian>X-NONE</w:LidThemeAsian>
<w:LidThemeComplex>X-NONE</w:LidThemeComplex>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w
ontGrowAutofit/>
<w:SplitPgBreakAndark/>
<w
ontVertAlignCellWithSp/>
<w
ontBreakConstrainedForcedTables/>
<w
ontVertAlignInTxbx/>
<w:Word11KerningPairs/>
<w:CachedColBalance/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
<m:mathPr>
<m:mathFont m:val="Cambria Math"/>
<m:brkBin m:val="before"/>
<m:brkBinSub m:val="--"/>
<m:smallFrac m:val="off"/>
<m:dispDef/>
<m:lMargin m:val="0"/>
<m:rMargin m:val="0"/>
<m:defJc m:val="centerGroup"/>
<m:wrapIndent m:val="1440"/>
<m:intLim m:val="subSup"/>
<m:naryLim m:val="undOvr"/>
</m:mathPr></w:Word>
Hi,
I need to run two cables to the main unit (mounted centrally high on the
windscreen). Now I could just run as best as possible with some bits exposed
but it will look a bit Heath Robinson and I'd rather have a neater more
permanent job.
One cable needs to go to a rear cam, the other to the 12v connector (although
I'd prefer another socket out of sight - drivers side footwell?)
Cable One
The rear cam is mounted on the glass at the highest point of the tailgate. First
problem is that there is a cable connector that needs feeding through to the
camera. I think that, without me drilling a hole, the only way through would
require the glass section of the tailgate being partially removed from the
metal frame - there is already a gap - perfect for the cable but not wide
enough for the connector (cylindrical in shape about 5/6 mm diameter) - is this
possible to remove the glass or is it
bonded in?
From there, there is already the rubber connector going between the boot lid
and the car body that carries the existing wires (for wiper, centre rear brake
light).
From here the direct route would be in the headlining. This keeps the cable at
the same height as the head unit, however the problem is the delicate nature of
the lining and finding a point from which to pull through. There is a large section
of trim that covers the A pillar - how does this come off without affecting the
roof lining? Giving it a gentle tug moves the lining. This would be perfect as
the final run to the unit is easy from here.
Cable Two
This needs to go down. Again, if the A pillar trim comes off then the job is
easy. I'm quite happy to have another 12v socket in the drivers footwell. I've
seen elsewhere that there is a spare terminal near the battery, can I just wire
a new one into here?
<!--if gte mso 9>
<w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemi="true" DefQat="false" DefPriority="99" LatentStyleCount="267">
<w:LsdException Locked="false" Priority="0" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Normal"/>
<w:LsdException Locked="false" Priority="9" Semi="false" UnhideWhenUsed="false" Qat="true" Name="ing 1"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 2"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 3"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 4"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 5"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 6"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 7"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 8"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 9"/>
<w:LsdException Locked="false" Priority="39" Name="toc 1"/>
<w:LsdException Locked="false" Priority="39" Name="toc 2"/>
<w:LsdException Locked="false" Priority="39" Name="toc 3"/>
<w:LsdException Locked="false" Priority="39" Name="toc 4"/>
<w:LsdException Locked="false" Priority="39" Name="toc 5"/>
<w:LsdException Locked="false" Priority="39" Name="toc 6"/>
<w:LsdException Locked="false" Priority="39" Name="toc 7"/>
<w:LsdException Locked="false" Priority="39" Name="toc 8"/>
<w:LsdException Locked="false" Priority="39" Name="toc 9"/>
<w:LsdException Locked="false" Priority="35" Qat="true" Name="caption"/>
<w:LsdException Locked="false" Priority="10" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Title"/>
<w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/>
<w:LsdException Locked="false" Priority="11" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Subtitle"/>
<w:LsdException Locked="false" Priority="22" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Strong"/>
<w:LsdException Locked="false" Priority="20" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Emphasis"/>
<w:LsdException Locked="false" Priority="59" Semi="false" UnhideWhenUsed="false" Name="Table Grid"/>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/>
<w:LsdException Locked="false" Priority="1" Semi="false" UnhideWhenUsed="false" Qat="true" Name="No Spacing"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 1"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 1"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 1"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/>
<w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/>
<w:LsdException Locked="false" Priority="34" Semi="false" UnhideWhenUsed="false" Qat="true" Name="List Paragraph"/>
<w:LsdException Locked="false" Priority="29" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Quote"/>
<w:LsdException Locked="false" Priority="30" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Intense Quote"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 1"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 1"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 2"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 2"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 2"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 2"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 2"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 3"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 3"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 3"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 3"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 3"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 4"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 4"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 4"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 4"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 4"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 5"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 5"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 5"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 5"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 5"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/>
<w:LsdException Locked="false" Priority="60" Semi="false" UnhideWhenUsed="false" Name="Light Shading Accent 6"/>
<w:LsdException Locked="false" Priority="61" Semi="false" UnhideWhenUsed="false" Name="Light List Accent 6"/>
<w:LsdException Locked="false" Priority="62" Semi="false" UnhideWhenUsed="false" Name="Light Grid Accent 6"/>
<w:LsdException Locked="false" Priority="63" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/>
<w:LsdException Locked="false" Priority="64" Semi="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/>
<w:LsdException Locked="false" Priority="65" Semi="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/>
<w:LsdException Locked="false" Priority="66" Semi="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/>
<w:LsdException Locked="false" Priority="67" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/>
<w:LsdException Locked="false" Priority="68" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/>
<w:LsdException Locked="false" Priority="69" Semi="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/>
<w:LsdException Locked="false" Priority="70" Semi="false" UnhideWhenUsed="false" Name="Dark List Accent 6"/>
<w:LsdException Locked="false" Priority="71" Semi="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/>
<w:LsdException Locked="false" Priority="72" Semi="false" UnhideWhenUsed="false" Name="Colorful List Accent 6"/>
<w:LsdException Locked="false" Priority="73" Semi="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/>
<w:LsdException Locked="false" Priority="19" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Subtle Emphasis"/>
<w:LsdException Locked="false" Priority="21" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Intense Emphasis"/>
<w:LsdException Locked="false" Priority="31" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Subtle Reference"/>
<w:LsdException Locked="false" Priority="32" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Intense Reference"/>
<w:LsdException Locked="false" Priority="33" Semi="false" UnhideWhenUsed="false" Qat="true" Name="Book Title"/>
<w:LsdException Locked="false" Priority="37" Name="Bibliography"/>
<w:LsdException Locked="false" Priority="39" Qat="true" Name="TOC ing"/>
</w:LatentStyles>
<!--><!--if gte mso 10>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-qformat:yes;
mso-style-parent:"";
mso-para-margin-top:0cm;
mso-para-margin-right:0cm;
mso-para-margin-bottom:10.0pt;
mso-para-margin-left:0cm;
line-height:115%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:"Times New Roman";
mso-fareast-theme-font:minor-fareast;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;}
<w:Word>
<w:Zoom>0</w:Zoom>
<w:TrackMoves/>
<w:Trackatting/>
<w
<w
<w:Compatibility>
<w
<w
<w
<w
</w:Compatibility>
<m:mathPr>
<m:dispDef/>
Hi,
permanent job.
Cable One
bonded in?
light).
Cable Two
<!--if gte mso 9>
</w:LatentStyles>
line-height:115%;
font-size:11.0pt;
