1 - 7 of 7 Posts
Hi guys, i have a 2014 hi up and i have the garmin sat nav unit and arm that mounts in the dash. Only problem is i dont have the 9 pin connector that that goes in the triangle holder in the dash or the wiring that goes from it to the radio. Can anyone tell me a part code for this or were i can buy one please ??
2013 Vw Up Black edition
Ive got the same unit in my Black Up edition, and unless all the electronic pins are in situ, on top of the dashboard and the necessary Vw software has been downloaded into the cars ECU, you will never custom fit it yourself.
The Garmin unit is rather good, especially the Sat / Nav, which has a very impressive mapping built in.
If parts are missing, or the necessary electronic connections are not present, then all i can suggest is to buy a Tom Tom or similar unit, and run it from the cigarette socket.
2014 High Up!, 75hp,Black
pretty sure Jason at citigoparts.co.uk will have a maps and more loom taken from a scrapper to sell you
1 - 7 of 7 Posts
