So after an abortive attempt with some TT Mk1 seats where we could not get them to work with my short daughter, I have put in a pair of A1 S-Line half leather. As someone said somewhere else on this forum, they are higher than standard, probably by about 25mm. They also tilt back slightly more.
This is what we did:
Steel plates bolted to the existing fixing points
The inside plate is 50mm wide then outside 85mm side shaped slightly to the rear.
1 short button-head bolt on the inside plate at the rear tapped and fixed with Loctite so that it become a stud.
Bolt the wide plate to the outside seat runner
Now fit the seat and the front inside is the original fixing hole. The rear inside is on the stud.
The outside is fixed to the original seat fixings.
Under the rear of each plate is a packing piece about 10mm thick to lift the rear of the seat.
Under the seat the airbag connector is the same.
The seat belt & heated seats need the connectors changing but that is simple.
For the occupancy sensor in the passenger seat and additional common wires needs adding as the original Audi fitting is all seat belt & sensor in a 3 pin connector.
I left the Audi seat belt clips on but you can remove them and put the original ones on but they are lower down.
The colours are pretty close with the main grey an almost perfect match and the centre panel close.
This is a 2016 5 door High Up! although the seats are from a 3 door but it does not really matter in this direction
