They have been replaced in your cars the water pump, TWICE? {in the same car}If "yes", please refer, after how many miles was each one of them.
If "no", it"s excellent.
Thank you!
from my experience the water pump was changed in combination with the timing belt - as a set, although it still works good..
Up water pumps are not run by the cam belt, they are on the other side of the engine and run by a small belt off the camshaft, so wouldn't be changed on a cam belt change.
I was convinced I heard a high-pitched squeal from mine last night, though I was following a slightly rough Merc A-Class!
I ask this question, because i want to keep my car for the next 3 years, and i don"t want to sell it.So, if there is anyone here who has bad experience with the SECOND WATER PUMP, please note that here.
THANK YOU
