What is the size of speakers i need to fit in the front and rear doors?I have a citigo 5dr but think it's the same for the UP!
I just installed a set of 6.5 component speakers on my 18 model 5 door Connect, found a set of Focals 165 designed for VW, easy job to do. I will install the 2 way coaxial 6.5” in the rears next week.
the front ones sound really well, look forward to install the rears.
5180
Carlos, you just revived an 8 year old thread...
To correct the first reply given, factory speakers are 145mm diameter (outer edge to outer edge) front and rear. You can fit 165-170mm speakers but be careful about them fouling the raised areas of the door card: there is only a small gap between them when the door card is refitted, and the speaker cone of a larger speaker could hit the door trim at high bass levels. You can trim the plastic on the door card if necessary.
