bugbabe34 said:
Delivery to the Uk for 6 euros and Jens said I can order through the website, but I still can't see where to select the UK in the drop down menu in the Pay Pal section.
If someone could advise I would be very grateful. You only need to add something to your basket, then click on Pay Pal and you can try to select the delivery country without entering any other info.
Pay Pal page
Hi BugBabe.
When I ordered mine, the Paypal site suggested that my adress was in Germany, and I could not change it there. But I wrote the correct country (Denmark) on the order form, and then also wrote a message in the optional message field, that it should be posted to Denmark. I received it within 3 days.
I would recommend that you order the "Montagerakel, Plastic" under the category "Montagezubehör" in the left menu (at the bottom). It is a piece of plastic, making it much easier to mount the foil nicely around the edges of the door sill.
Remember to clean the door sill, and spray both the door sill and the foil with water from a spray bottle (I filled one with 1 litre of water and 3 small drops of liquid soap).
There is a small video on the website, showing how to position the foil parts.
When you recieve the foil, one end is marked with a small circle, saying "VS" or something similar. That should be equal to the the left front door (opposite of drivers seat in the UK).
Anyway, feel free to send me a PM, if you need any help
Best regards,
Kenneth
