1 - 12 of 12 Posts
Hi, does anyone have any tips on how to remove the dealer sticker from inside of the rear screen?
Someone posted on this subject a whole ago but I can't find it now.
HH
I feel your pain....I tell them not to put one on in the first instance and if they do, get them to remove it with the proviso they replace the rear hatch if the break a heating element.
I'd imagine heat to soften the glue then peel and mild solvent....I use injection swabs...isopropyl alcohol for sticker removal but then again there are loads lying around here!
Just warm the sticker with a hair dryer (do it for 3 or 4 minutes) and it will be easy to remove it...
Have you tried pulling it off? Mine removed easily and then I used a normal glass cleaner on the window to remove any mark - I'm quite awkward about things like that and it worked perfectly!
WD40 works a treat on sticky marks too!
I use the hairdryer trick!
Great stuff!!
It wouldn't be so bad if they paid you for advertising
Thanks for all the helpful hints which will come in handy next Saturday pickup day
Mine only says "www.volkswagen.fi" so I don't mind giving a little support for my favourite brand ;)
Luckily our dealer must have a policy of not sticking them on, or forgot to
1 - 12 of 12 Posts
