I've begun to notice a strange noise both when ignition is turned on or off. On switching on there is a slight delay and then the noise occurs at the same time the fuel gauge rises. Then again when turning off the ignition the same noise appears. Let me know next time you go out in your UP if this is normal, I'm sure I've never heard it before. Thanks.
