Just pick up a new up and the only problem so far is the tyre pressure warning light keeps coming. Ive reset it several times , but back it comes. Is this a common problem on up's?
Hi, have you checked all the tyre pressures? you may have a slow puncture.
Not sure which method they use to monitor the tyre pressure on the Up! but if its the in wheel sensor type it could be faulty.
Mike
