1 - 7 of 7 Posts
I would assume so, given many earlier or "lesser" models have it. But ask the seller
It's the very basic ABS sensor-based system - it monitors changes in relative rotational speeds, not actual pressures though...
A good thing.
I didn't realize it was all cars sold, wrongly thinking it was only new models introduced after 2014!
Yes so once you have all tyres to the same pressure* switch on and locate the button by opening the glove box then press to set/reset it.
* Pressure is an interesting topic. My 2018 one had owners manual plus the door pillar sticker saying 41 PSI. The new (2021) version has the same dimensions, wheels and tyres - maybe a little more weight if anything - but the sticker says 36 PSI and the new, more useless handbook says "look at the sticker". That seemed a tad too soft so I "homed in" on a compromise of 39 PSI . 4000 miles later and the wear pattern looks ideal so I will keep that. wonder why VW changed it (perhaps to save springs/ shox?)
1 - 7 of 7 Posts
