Just checked my front tyres on my up! white and noticed that they are starting to get quite low on tread. I think they are on just shy of 1.5mm. The trouble is the car has only done 14000 miles and I thought tyres should last quite a bit longer than this. My car came with the Continental Conti Premium Contact 2s (185/50/r16).
Does anybody know if this is normal? I did check the pressures and all tyres were out by about 4psi so have pumped them up to the correct pressures as indicated on the sticker on the filler cap - 29psi fronts and 26psi on the rears. Probably should have checked before really but just assumed that this kind of thing would be correct on a new(ish) car!
