How does that work anyway? sliding vipers around the column or something? - if so i could imagine it would get worn down over time?shakotanVIP said:The steering column will have connections to allows the signals from the buttons on the steering wheel to translate into the wiring in the steering column. Like the horn, this cannot be a physical wired connection, as the wires would twist and break when you turned the steering wheel.
+1!stratcast said:Stupid that theydon'toffer this feature, I would have paid 500GBP easily.
shakotanVIP said:You get get aftermarket stereos with a remote control that clips to the steering wheel.
Here's a piccy the the wheel on the review.chris_42 said:I came across this video review and for a moment it had me wondering.
I've found no reference to steering wheel controls in any of Volkswagen's sales literature yet here the presenter has his hands on such a wheel ""” purportedly inside an up! ""” at 9:37.
Closer inspection reveals the tell-tale light switch on the dash, showing that the insert edit is lifted from another review, probably a Beetle.
Bit misleading...![]()
