- Privatedoc.
Sorry for the slow reply, Ive been at work for the last few days.
I use Blackvue 400 HD, which I ordered from Ebay for £138 a few months back (not sure on the price now) if you want the sellers name I can PM you that. I'm not sure the policy on promoting sellers?
It goes neatly behind the Rear view mirror, I cant see it when driving. an its not to obvious from the outside too.
Since the 12V plug inside the up is diconnected from the battery when the engine is turned off I can leave it plugged in and forget about it.
Rumour has it you can obtain a % off your insurance cost as well since it records speed and position. - I still need to ring mine to ask - forgot about that.
Comes with software to show your location on google maps, your journey start/finish and route and where any incidents you had took place. The camera has 3 Gforce detectors on, for breaking/accelarating and records any big bumps, large speed bumps etc.
Its the only one I've ever had so I cannot personally compare them, however its a true 1280x 720, 30 fps. The pictures I'm posting are just screen dumps of the paused camera and then cut down to fit the forums picture size limits.
Hope some of that helps. If you can think of other questions i'll have a crack at them.
Ben
