Lambo-27 said:What about 7" ET40? That would bring it away from the strut and with the right tires the arch will go over the wheel?
I think you are really not getting that if you go wider than 6.5 on the front you wont get any tuck, also writing from someone with ET40 already i would not want to move another 1mm closer to strut its close enough for you not to get a pound coin between inner of rim and strut.Lambo-27 said:Yeah true! Thought that right after I posted it! Haha
My problem is that I want to tuck the front wheels into the archs though, so I may go for 7" ET45 then space them out away from the strut perfectly then give the front arches a roll extending them abit
your ride height can be what you want as you order custom bags.Lambo-27 said:Hmmm that doesn't sound good :/ might be harder than I thought!
That proposes the question, should I then go for 16's because I'm looking at air ride and 16's will get me s good bit lower but might look silly at ride height. To be honest I think I just need to go for it and if I make the wrong decision I can sell them! They hold they're money quite well!
