1 - 20 of 66 Posts
I finally got the car and plugged it in...
There isn't a mapping for the BCM in the 2013 UP! yet... However, I made some assumptions based on the Golf 6, and I managed (with some help from Ross-Tech) to get the two things working that I wanted!
1) Doors lock when you drive off
2) One click of remote only unlocks drivers door, double click unlocks all doors...
I tried to get the comfort windows working, but all the coding I tried for that didn't work :(
Comfort Windows is the ability to raise and lower them from the remote by holding down lock or unlock.
SiJ2000, nice upgrades You have made.Unfortunately windows in Up are so cut, that You can'tprogramto comfort.. There's just no hardware for that.
I have talked with VW technical specialist, who trains service guys..
I was told the door lock feature was not available. Can it be confirmed if this is available on the 2012 model, or just the 2013 as a new feature?
My car is 2012.
Thanks..
I imagine that it would be in alll the BCMs... Don't believe that it itsn't in the 2012 one...
I'm not gonna give up on the window thing, not completely convinced that it would be a hardware limitation as the systems are all CAN controlled anyway... let's see what happens...
What i have done with VCDS is to set-up the comfort blinking from 3 to 5 blinks...
That's cool... am struggling a bit as there are no labels for the BCM. (Cent Elec) on my model (new 2013)... am using different files for tests...
I assume you did that through adaptation??
Discussion Starter · #8 ·
To respond to one of the earlier comments, believe there are a few bariations to the BCM depending on model/spec, so some models may not be able to have some of these codes...
I have a high up, so hopefully it would be good enough.
Discussion Starter · #10 ·
The UP! Black is based on the High Up... I'll keep playing...
Using VCDS 11.11.4.on 2012 High up! I cant get auto locking or the key bleep.So may be it is only on 2013my.
Many thanks for investigating..
Discussion Starter · #13 ·
Try Byte 0, Bit 4 for the lock when you drive off....Try Byte 0, Bit 0 for the single door lock...
Let us know if it works...
Still no luck with the auto comfort windows...
Of what I've read on other forums it seems the Up doesn't have a comfortmodule installed... so you can't program it?
I wonder if it would be difficult to install one and what it might cost..
Discussion Starter · #15 ·
Yeah maybe!
Did you try the door locking stuff again?
Discussion Starter · #17 ·
How annoying! hope you get it soon! plugging in the vcds is the first thing did!
Many thanks Byte 0 Bit4 works on 2012my.
Are you saying I can get the auto door locking on my 2012 high up?
What would I need to tell my dealer they have to do?
Many thanks ...
Yes you can have auto locking on your High up!2012my.Your dealer does not use vcds VW have there own system but it performs the same functions.If they get into 09Central electrics they should be able to locate the code & modify it as previously mentioned Byte0 Bit4
1 - 20 of 66 Posts
