Hi, does anyone on here have the vw type? I have a set on order and have question about fitting. I have a hapro 350 roady box which attaches using a u bolt fixing. Will this work on the vw bars?
If the bars are square you should be ok with the fixings.
I have the thule roof bars.
I think they are the blade type. Looking into a bit more, you can buy adapters that slide down the bars. Will just have to sort it when it arrives.
I have VW bars and they have the rail on top, so it should be possible to fit anything - only with the correct mount/ legs
