Hi all,
My name is Krystian, I'm new in the forum.
I've got VW UP 1.0., y. 2015.
I've got quite weird technical issue which is really annoying once there is freeze outside
I've got no:
- blower at all (all gears), therefore no heating as well
- 12V stock
- rear wiper
It all broke down in the same time - maybe something else is broken but those 3 I know.
All fuses are OK.
What I diagnosed is that there is no power (voltage) controlling the relay (B644 - most on the left side looking from the driver perspective - the wheel is on the left side as the car is for Polish market). All relays are OK.
Currently we have found some temporary solution. There is a "bridge" mounted and the power into the relay's coil is directly from battery but obviously I cannot drive in such way for a long time
I do not have any electric diagrams - have not found any online.
Without electric diagram it is extremely difficult to find out where is the issue as it may be everything, any cable broken etc.
One more thing - it might be just coincidence but it all happend just after I replaced the front bulb H4 (driver side). Currently it works (lights), I've also disconnected it for a while but it didn't help.
Does anyone recall such problem? I will appreciate any kind of suggestions, support.
Thank you!
Krystian
Edited by: stasiakkrystian
I've got no:
- 12V stock
- rear wiper
All fuses are OK.
Thank you!
Krystian
