1 - 1 of 1 Posts
Discussion Starter · #1 · (Edited)
Description
Increase your Comfort and enjoyment When driving your VW Up! The armrest is also a handy storage compartment for small items where they can be kept within easy reach.
Please note:
When retrofitting, the cup holder must be partially cut out to allow the armrest to fit as designed. Once fitted the cup holder is concealed by the Armrest assembly which fits over the cup holder. This action is reversible should you decide to remove the armrest at a later stage. This will require a replacement cup holder assembly. This is a high quality OEM part made in Austria and designed to mechanically secure to existing fixing points on the floor plan of the central tunnel with a set of screws and nuts provided. There are other cheap alternatives on the market that fits differently and these are less sturdy and or reliable once fitted.
Fitting time approximately 30 minutes for somebody that has reasonable DIY skills. Comes with clear fitting instructions. There is also a You Tube video available which demonstrates the full installation clearly.
Features & details
  • New, unused
  • Colour: black
  • For Volkswagen up! MY 2011 - 2019
  • Storage compartment for small items
  • Foldable armrest
  • Armrest also extends forward when flat for added comfort
  • Requires 30 minutes fitting with medium DIY skills
  • All fittings and fixtures included
    Wood Material property Font Rectangle Flooring
    Bicycle handlebar Sculpture Bicycle part Automotive exterior Auto part
    Audio equipment Automotive design Wing Gas Security
    Rectangle Wood Shelving Material property Tints and shades
    Automotive tire Automotive design Comfort Fender Synthetic rubber
    Audio equipment Automotive design Gadget Gas Camera
    Wall Material property Gas Flooring Space
    Font Paper Paper product Document Office equipment
    Font Paper Transparency Gas Rectangle
1 - 1 of 1 Posts
