1 - 9 of 9 Posts
Hi I am having trouble finding a part I need. The white connector part that you plug the light into has corroded and need a new one. But I have no idea what it is called.
Hi there,
Could you clarify which light you mean, please? One of the headlights, rear lights, the interior light, the 12V power port?....
Ok, thanks. The version of ETKA (parts catalogue) that I can access doesn't indicate different headlights for the Street Up!, so I'm assuming it will be the same as the regular Up!s:
4915
If by 'plug the light into' you mean the part that is visible from the front of the car with glass and reflectors, that is only available as an entire unit: on rhd cars the part code is #1S1 941 015 for left and #1S1 941 016 for right headlight; final letter of the code is M for black or N for chrome finish.
If you mean the part at the back of the light bulb, I think you want the part labelled #6 above, which is called a 'cover cap' and is part #1S0 941 607. Beyond that the power connection is from the main wiring harness; I believe the connector is part #8L0 973 703 ('flat contact housing with contact locking mechanism for headlamps, 3-pin'); looks like this:
If none of the above, could you clarify further which part you need, please?
Thanks for the clarification. Finally found it on the wiring harness list - another 'flat contact housing': #161 941 165
Hi there,
As far as I can tell, that part is used for H4 bulbs across most of the VAG range:
Could you explain why you don't think it fits your car, please?
It may also be worth looking at the list on ETKA yourself:
Pick the year of manufacturer and engine code (I believe the Street Up! is CHYB/75bhp), then the electrics menu, then the item 'central wiring set the connector housing is found in the individual...'. All connectors from the main wiring harness are on here.
1 - 9 of 9 Posts
