As i open the door on the up! Under the trim on the paint to the rear is a plate with a hole in it. Corresponding on the door frame is a recess with a black plastic trim where the plate locates when shut. Theres nothing in the recess.
Is this a deadlock option on higher models ? Had the same on the polo for the last 3yrs and never figured it out.
Supermegamonkee said:
Adds strength to the car in the event of a crash. Hth
Really cant seehow it adds anything if its not locked in place. Which it isnt. If that was the case why put a hole in it?
The hole suggests a locking pin which isnt there. Possibly something from a foriegn model?
side impact protection, if you hit the door, the door caves in and the plate angles down and locks...needed on the 3 door because the door is long
That makes sense, my last two vws both 3dr. Hope i never get the use out of it !!!
