Help please.
My daughter's Up! has had an argument with a big pothole. Damage to both passenger side tyres, but the wheels look OK. Tyres have been replaced, but we now need to get wheel alignment checked. We have no idea whether the rear wheels are even adjustable, so not sure whether it is worth paying the extra for a four wheel alignment. Anyone here have any idea whether rear Up! wheels are adjustable?
Cheers.
hi and welcome
rears are not adjustable
if you are experiencing any horrible feedback, chances are its the wheel, its buckled..
Always 4 wheel and Hunter equipment preferably.
They might not be able to adjust the rears but they'll be lined up properly with the front then.
We had our wheel alignment checked after hitting a pot hole.
The VW dealer can do it, as mentioned above the rear is not adjustable. If the rear is out then you’d need new parts to repair as required. You would have to hit a pretty bad pot hole to damage the suspension though.
Is the steering wheel still perfectly aligned when you are driving straight? (As in, not offset to the left or right)
If the wheel is still straight then you are probably OK.
