Been asked many times before but will 15 x 8.25 et 0 fit the up. Stretch tyres to be fitted.
want to order but need to make sure they fit!
thanks
I would use willtheyfit.com and tyrestrech.com to get a good reference as to how they poke with what stretch.
As a reference point my wheels sit like this:
They are 17x7 et23 with 195/40/r17. Gives your a reference point for willtheyfit.com
From what I quickly looked at on willtheyfit and tyrestretch, you'll be poking too much without major camber.
I don't know a huge amount about stretch and running camber however so maybe someone abit more knowledgeable than myself will chip in.
Personally, I think 8.25 +0 is probably a bit strong. If you're willing to run as much negative camber as you can dial (around 3deg) you may get close.
Without any additional negative camber I ran 8 +30 on 185/35s, and they were as tight as you like.
Balls, only wheels i like, i don't like much camber either. Its not like i can roll the arches much either. Hmmm may email manufacture and see if they will make a custom set with a higher et?
