1 - 12 of 12 Posts
Hi all,
I am after purchasing a wheel alignment tool. Without trying to teach grandma to suck eggs, it is a 6" long circular bar with a thread the same as the wheel nut on one end and on the other end a knurled textured section and a slotted end to aid with removal. You screw it into a wheel nut hole and simply pass it through a wheel nut hole on your wheel when fitting and it locates your wheel perfectly with all the wheel nut holes lined up.
Can anyone tell me the size and thread pattern I need. I cannot find this information anywhere. The measurement will be something like M14x1.5 I have the 16" Sports Pack Triangle Alloys, if that makes a difference.
No worries at all mate, I was only looking at the end of last week as I had to order some longer wheel bolts myself.
Hi Den, your right, its not a great issue but it just makes the job a little easier. I had a motorcycle accident a few years back and lost the use of my right arm, eventually having it amputated. Every so often I like to swap my wheels between my classics and triangles. I like to remove them periodically too to thoroughly clean the arches and the inside of the wheels, I polish them up with Collinite 845 to ease removal of the dreaded brake dust. Call me fussy, sad, mad whatever but I'll have to agree with you.
If your really fussed about changing wheels you could just get double ended threaded studs and change wheel fittings to nuts.
I used some on my T25 bus adaptors as they were not hubcentris on the rear, it made it so much easier to change and centre properly.
Edited by: 2020mad
I bought this for my Skoda Citigo. The car's only just over a month old so I haven't actually tried it yet. The eBay seller (Kev) was very friendly and helpful too. It was dispatched immediately and arrived very quickly.
http://www.ebay.co.uk/itm/190810410630?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I was worried that it might not fit my Skoda Citigo (or Volkswagen up! or Seat Mii) but Kev assured me that it would.
<!--if !mso>
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
<t></t><table ="msonormaltable"="" style="width:100.0%;mso-cellspacing:2.2pt;mso-yfti-tbllook:1184;mso-padding-alt: 1.5pt 1.5pt 1.5pt 1.5pt" border="0" cellpadding="0" cellspacing="3" width="100%">
<t><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes;mso-yfti-lastrow:yes">
<td style="padding:1.5pt 1.5pt 1.5pt 1.5pt">
Hi,
This will infact work on your car as your car does hold a M12x1.5 Bolt.
Many Thanks
Kev <br style="mso-special-character:line-break">
- pluset
</td>
<td style="width:138.75pt;padding:1.5pt 1.5pt 1.5pt 1.5pt" valign="top" width="185">
</td>
</tr>
</t></table>
<div ="msonormal"="" style="text-align:center" align="center">
<hr align="center" size="2" width="100%">
Dear pluset,
Your headline states "Alloy Wheel Fitting Alignment tool Skoda Felica
CITIGO M12x1.5 12x1.5" but when I check further down your listing for
compatibility it states that it's not compatibile with a Skoda Citigo.
"This item does not fit Skoda Citigo 2013."
Is this tool suitable for a Skoda Citigo or not?
Thank you.
</td>
</td>
</tr>
</t></table>
<!--if gte mso 9>
<o:OfficeSettings>
<o:AllowPNG/>
</o:OfficeSettings>
<!--><!--if gte mso 9>
<w:Word>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:TrackMoves/>
<w:Trackatting/>
<w:punctuationKerning/>
<w:ValidateAgainstSchemas/>
<w:DonotPromoteQF/>
<w:LidThemeOther>EN-GB</w:LidThemeOther>
<w:LidThemeAsian>X-NONE</w:LidThemeAsian>
<w:LidThemeComplex>X-NONE</w:LidThemeComplex>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:DontGrowAutofit/>
<w:SplitPgBreakAndark/>
<w:EnableKerning/>
<w:DontFlipMirrorIndents/>
<w:OverrideTableStyleHps/>
</w:Compatibility>
<m:mathPr>
<m:mathFont m:val="Cambria Math"/>
<m:brkBin m:val="before"/>
<m:brkBinSub m:val="--"/>
<m:smallFrac m:val="off"/>
<m:dispDef/>
<m:lMargin m:val="0"/>
<m:rMargin m:val="0"/>
<m:defJc m:val="centerGroup"/>
<m:wrapIndent m:val="1440"/>
<m:intLim m:val="subSup"/>
<m:naryLim m:val="undOvr"/>
</m:mathPr></w:Word>
<w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="false" DefSemi="false" DefQat="false" DefPriority="99" LatentStyleCount="371">
<w:LsdException Locked="false" Priority="0" Qat="true" Name="Normal"/>
<w:LsdException Locked="false" Priority="9" Qat="true" Name="ing 1"/>
<w:LsdException Locked="false" Priority="9" Semi="true" UnhideWhenUsed="true" Qat="true" Name="ing 2"/>
<w:LsdException Locked="false" Priority="9" Semi="true" UnhideWhenUsed="true" Qat="true" Name="ing 3"/>
<w:LsdException Locked="false" Priority="9" Semi="true" UnhideWhenUsed="true" Qat="true" Name="ing 4"/>
<w:LsdException Locked="false" Priority="9" Semi="true" UnhideWhenUsed="true" Qat="true" Name="ing 5"/>
<w:LsdException Locked="false" Priority="9" Semi="true" UnhideWhenUsed="true" Qat="true" Name="ing 6"/>
<w:LsdException Locked="false" Priority="9" Semi="true" UnhideWhenUsed="true" Qat="true" Name="ing 7"/>
<w:LsdException Locked="false" Priority="9" Semi="true" UnhideWhenUsed="true" Qat="true" Name="ing 8"/>
<w:LsdException Locked="false" Priority="9" Semi="true" UnhideWhenUsed="true" Qat="true" Name="ing 9"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index 4"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index 5"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index 6"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index 7"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index 8"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index 9"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Name="toc 1"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Name="toc 2"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Name="toc 3"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Name="toc 4"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Name="toc 5"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Name="toc 6"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Name="toc 7"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Name="toc 8"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Name="toc 9"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Normal Indent"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="footnote text"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="annotation text"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="er"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="footer"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="index ing"/>
<w:LsdException Locked="false" Priority="35" Semi="true" UnhideWhenUsed="true" Qat="true" Name="caption"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="table of figures"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="envelope address"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="envelope return"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="footnote reference"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="annotation reference"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="line number"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="page number"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="endnote reference"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="endnote text"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="table of authorities"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="macro"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="toa ing"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Bullet"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Number"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List 4"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List 5"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Bullet 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Bullet 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Bullet 4"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Bullet 5"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Number 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Number 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Number 4"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Number 5"/>
<w:LsdException Locked="false" Priority="10" Qat="true" Name="Title"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Closing"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Signature"/>
<w:LsdException Locked="false" Priority="1" Semi="true" UnhideWhenUsed="true" Name="Default Paragraph Font"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Text"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Text Indent"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Continue"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Continue 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Continue 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Continue 4"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="List Continue 5"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Message er"/>
<w:LsdException Locked="false" Priority="11" Qat="true" Name="Subtitle"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Salutation"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Date"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Text First Indent"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Text First Indent 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Note ing"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Text 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Text 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Text Indent 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Text Indent 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Block Text"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Hyper"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="FollowedHyper"/>
<w:LsdException Locked="false" Priority="22" Qat="true" Name="Strong"/>
<w:LsdException Locked="false" Priority="20" Qat="true" Name="Emphasis"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" "/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Plain Text"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="E-mail Signature"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Top of "/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Bottom of "/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Normal Web"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Acronym"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Address"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Cite"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Code"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Definition"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Keyboard"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Preatted"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" le"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" r"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name=" Variable"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Normal Table"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="annotation subject"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="No List"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Outline List 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Outline List 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Outline List 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Simple 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Simple 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Simple 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table ic 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table ic 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table ic 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table ic 4"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Colorful 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Colorful 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Colorful 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Columns 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Columns 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Columns 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Columns 4"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Columns 5"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Grid 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Grid 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Grid 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Grid 4"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Grid 5"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Grid 6"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Grid 7"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Grid 8"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table List 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table List 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table List 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table List 4"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table List 5"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table List 6"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table List 7"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table List 8"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table 3D effects 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table 3D effects 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table 3D effects 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Contemporary"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Elegant"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Professional"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Subtle 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Subtle 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Web 1"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Web 2"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Web 3"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Balloon Text"/>
<w:LsdException Locked="false" Priority="39" Name="Table Grid"/>
<w:LsdException Locked="false" Semi="true" UnhideWhenUsed="true" Name="Table Theme"/>
<w:LsdException Locked="false" Semi="true" Name="Placeholder Text"/>
<w:LsdException Locked="false" Priority="1" Qat="true" Name="No Spacing"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading"/>
<w:LsdException Locked="false" Priority="61" Name="Light List"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 1"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 1"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 1"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 1"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 1"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 1"/>
<w:LsdException Locked="false" Semi="true" Name="Revision"/>
<w:LsdException Locked="false" Priority="34" Qat="true" Name="List Paragraph"/>
<w:LsdException Locked="false" Priority="29" Qat="true" Name="Quote"/>
<w:LsdException Locked="false" Priority="30" Qat="true" Name="Intense Quote"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 1"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 1"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 1"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 1"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 1"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 1"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 1"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 1"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 2"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 2"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 2"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 2"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 2"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 2"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 2"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 2"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 2"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 2"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 2"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 2"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 2"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 2"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 3"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 3"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 3"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 3"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 3"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 3"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 3"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 3"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 3"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 3"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 3"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 3"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 3"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 3"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 4"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 4"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 4"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 4"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 4"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 4"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 4"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 4"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 4"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 4"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 4"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 4"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 4"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 4"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 5"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 5"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 5"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 5"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 5"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 5"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 5"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 5"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 5"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 5"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 5"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 5"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 5"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 5"/>
<w:LsdException Locked="false" Priority="60" Name="Light Shading Accent 6"/>
<w:LsdException Locked="false" Priority="61" Name="Light List Accent 6"/>
<w:LsdException Locked="false" Priority="62" Name="Light Grid Accent 6"/>
<w:LsdException Locked="false" Priority="63" Name="Medium Shading 1 Accent 6"/>
<w:LsdException Locked="false" Priority="64" Name="Medium Shading 2 Accent 6"/>
<w:LsdException Locked="false" Priority="65" Name="Medium List 1 Accent 6"/>
<w:LsdException Locked="false" Priority="66" Name="Medium List 2 Accent 6"/>
<w:LsdException Locked="false" Priority="67" Name="Medium Grid 1 Accent 6"/>
<w:LsdException Locked="false" Priority="68" Name="Medium Grid 2 Accent 6"/>
<w:LsdException Locked="false" Priority="69" Name="Medium Grid 3 Accent 6"/>
<w:LsdException Locked="false" Priority="70" Name="Dark List Accent 6"/>
<w:LsdException Locked="false" Priority="71" Name="Colorful Shading Accent 6"/>
<w:LsdException Locked="false" Priority="72" Name="Colorful List Accent 6"/>
<w:LsdException Locked="false" Priority="73" Name="Colorful Grid Accent 6"/>
<w:LsdException Locked="false" Priority="19" Qat="true" Name="Subtle Emphasis"/>
<w:LsdException Locked="false" Priority="21" Qat="true" Name="Intense Emphasis"/>
<w:LsdException Locked="false" Priority="31" Qat="true" Name="Subtle Reference"/>
<w:LsdException Locked="false" Priority="32" Qat="true" Name="Intense Reference"/>
<w:LsdException Locked="false" Priority="33" Qat="true" Name="Book Title"/>
<w:LsdException Locked="false" Priority="37" Semi="true" UnhideWhenUsed="true" Name="Bibliography"/>
<w:LsdException Locked="false" Priority="39" Semi="true" UnhideWhenUsed="true" Qat="true" Name="TOC ing"/>
<w:LsdException Locked="false" Priority="41" Name="Plain Table 1"/>
<w:LsdException Locked="false" Priority="42" Name="Plain Table 2"/>
<w:LsdException Locked="false" Priority="43" Name="Plain Table 3"/>
<w:LsdException Locked="false" Priority="44" Name="Plain Table 4"/>
<w:LsdException Locked="false" Priority="45" Name="Plain Table 5"/>
<w:LsdException Locked="false" Priority="40" Name="Grid Table Light"/>
<w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark"/>
<w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful"/>
<w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful"/>
<w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light Accent 1"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 1"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 1"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 1"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 1"/>
<w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful Accent 1"/>
<w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful Accent 1"/>
<w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light Accent 2"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 2"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 2"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 2"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 2"/>
<w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful Accent 2"/>
<w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful Accent 2"/>
<w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light Accent 3"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 3"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 3"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 3"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 3"/>
<w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful Accent 3"/>
<w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful Accent 3"/>
<w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light Accent 4"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 4"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 4"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 4"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 4"/>
<w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful Accent 4"/>
<w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful Accent 4"/>
<w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light Accent 5"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 5"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 5"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 5"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 5"/>
<w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful Accent 5"/>
<w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful Accent 5"/>
<w:LsdException Locked="false" Priority="46" Name="Grid Table 1 Light Accent 6"/>
<w:LsdException Locked="false" Priority="47" Name="Grid Table 2 Accent 6"/>
<w:LsdException Locked="false" Priority="48" Name="Grid Table 3 Accent 6"/>
<w:LsdException Locked="false" Priority="49" Name="Grid Table 4 Accent 6"/>
<w:LsdException Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 6"/>
<w:LsdException Locked="false" Priority="51" Name="Grid Table 6 Colorful Accent 6"/>
<w:LsdException Locked="false" Priority="52" Name="Grid Table 7 Colorful Accent 6"/>
<w:LsdException Locked="false" Priority="46" Name="List Table 1 Light"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark"/>
<w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful"/>
<w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful"/>
<w:LsdException Locked="false" Priority="46" Name="List Table 1 Light Accent 1"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 1"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 1"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 1"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 1"/>
<w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful Accent 1"/>
<w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful Accent 1"/>
<w:LsdException Locked="false" Priority="46" Name="List Table 1 Light Accent 2"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 2"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 2"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 2"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 2"/>
<w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful Accent 2"/>
<w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful Accent 2"/>
<w:LsdException Locked="false" Priority="46" Name="List Table 1 Light Accent 3"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 3"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 3"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 3"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 3"/>
<w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful Accent 3"/>
<w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful Accent 3"/>
<w:LsdException Locked="false" Priority="46" Name="List Table 1 Light Accent 4"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 4"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 4"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 4"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 4"/>
<w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful Accent 4"/>
<w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful Accent 4"/>
<w:LsdException Locked="false" Priority="46" Name="List Table 1 Light Accent 5"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 5"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 5"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 5"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 5"/>
<w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful Accent 5"/>
<w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful Accent 5"/>
<w:LsdException Locked="false" Priority="46" Name="List Table 1 Light Accent 6"/>
<w:LsdException Locked="false" Priority="47" Name="List Table 2 Accent 6"/>
<w:LsdException Locked="false" Priority="48" Name="List Table 3 Accent 6"/>
<w:LsdException Locked="false" Priority="49" Name="List Table 4 Accent 6"/>
<w:LsdException Locked="false" Priority="50" Name="List Table 5 Dark Accent 6"/>
<w:LsdException Locked="false" Priority="51" Name="List Table 6 Colorful Accent 6"/>
<w:LsdException Locked="false" Priority="52" Name="List Table 7 Colorful Accent 6"/>
</w:LatentStyles>
<!--><!--if gte mso 10>
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman","serif";}
Edited by: Robbyrook
As for Granny sucking eggs ...
Don't jack it up! so high that the wheel lifts off and stays off the ground.
Jack it up until the suspension play is taken up, then ever so slightly lower it again.
The wheel will remain on the ground while you wiggle it about until it fits the holes / bolts.
It won't drop down when removing the bolts, and you won't have to lift the wheel either when refitting.
Studs in the hub are a better idea IMO.
Discussion Starter #10
I don't jack it up that high, after 20 years in transport, I think I know how to change a wheel. You'd struggle to get a *** paper between the floor and the bottom of the tyre and then I tweak the jack so it matches the height of the wheel centre being put on. Try it one handed, left handed at that or which ever is your least dominant hand, it ain't that easy. £6.99 for a simple tool to make the job that bit easier is money well spent, especially on a dark cold winters night at the side of the road. I bought an M12x1.5 wheel alignment tool today off eBay and can't wait for it to arrive.
JonWilliams, you're a star! It's a struggle to jiggle heavy wheels/tyres with two hands and I can't imagine how you manage with only one.
Sure Jon, whatever makes it more convenient in your situation is obviously OK.
It's just that I often see ppl lifting their wheels way off the ground, which only makes it tougher.
1 - 12 of 12 Posts
