1 - 12 of 12 Posts
Got my new Piaa mirror white drl To go with my MTEC supper white H4's
[/IMG]
[/IMG]
[/IMG]
Spud
Those DRL look great, what is the product code for them and where can I order them from.
Only place I found them was eBay search for 'piaa 580' there are 2 types extra white which have blue bulbs and the mirror white which I went for, they are not cheap though
Edited by: spud
The extreme whites are a bit cheaper by about £10 but I had a bit to drink and I seen how shiny the others were
Discussion Starter #8
HI did you need to fit a resistance limiter in thewiring?
if yes what type did you use and was it easy?
<a href="http://www.ledmania.it/shop/7443-w21/5w-lampada-tuttovetro-15mm-attacco-doppio-led-metallico-lenticolare-6w-bianco-lunare-5000k-p627.html" target="_blank" rel="nofollow">
http://www.ledmania.it/shop/7443-w21/5w-lampada-tuttovetro-15mm-attacco-doppio-led-metallico-lenticolare-6w-bianco-lunare-5000k-p627.html</a>
Here is the link ....
I live in Italy and this is the seller ..... :( maybe make shipments abroad ....
No, no resistance! :)
It took me 30 seconds to install, at 3000 km and they are perfect, turning on the machine at least 4 times a day
Are longer than 2 cm of the original
Edited by: Collas
Discussion Starter #11
jezyg said:
I went with MTEC Bulbs for both the DRL and main lights.
I could not find the mtec ones where did you get them
1 - 12 of 12 Posts
