The left hand nearside washer jet on my Up GTi has become weak and is lacking in water pressure spray......the drivers side is fine. Ive tried replacing both washer jets with new but its still the same. Has anyone else had any similar experiences. ?.
Hi there,
Assuming it's the same as a standard Up!, the plumbing for the washer fluid is a single feed up to a Y-piece that splits the fluid between the two jets. If fluid is coming out of the driver's side ok then the fundamentals (pump, reservoir, electrics) are working because this is the furthest point of the system. You've probably got a blockage/restriction in the line between the Y-piece (#5) and the passenger-side jet (#4):
4806
No exact instructions in the Workshop Manual, but I'd start with seeing if the hose has become pinched/kinked, then try disconnecting it from the Y-fitting and backflushing.
