Has anyone attempted a full brake upgrade i.e. disks, pads, lines etc especially for upgrading the rear drums to disks..what brands are available etc
If you want to stop quicker then upgrade the tyres first.Has anyone attempted a full brake upgrade
Most implementations of this I’ve personally experienced are pretty simple. There’s a restrictor valve in the hydraulic line which feeds the rear brakes connected to the rear suspension by a lever and spring. As the ride height changes, the lever opens or closes the restrictor to alter the fluid flow to the rear brakes accordingly. No electronics or clever control 👍Many cars have a load mechanism for the rear, often just measuring the the angle of the rear axle line to the body. It modulates the hydraulic pressure to the rear, and allows more pressure to rear if the rear is loaded up.
