SUCCESS!!
I finally got my parts and installation was plug'n'play as I hoped!
Parts you need from Volkswagen:
Navigation screen
(OE-#: 1S0 035 262 A)
Navigation arm
(OE-#: 1S0 035 936 A)
Metal bracket
(OE-#: 1S0 857 269 A)
Wiring harness
(OE-#: 1S0 035 935)
Optional:
Cover plate
(OE-#:1S0 035 491)
Part numbers are listed in an earlier post
My parts arrived this morning with GLS:
Navigation screen:
It needs to be connected to car (as expected):
"Navigation arm":
Wiring harness:
There are three connectors (the third is hidden under the protective foam tube). Two antenna connectors and one multi-connector:
Metal bracket:
So this afternoon I started installing the kit!
Preparing for the cut:
Getting close:
The cover plate fits!:
The metal bracket clicks right into the hooks (hooks are molded into dash):
From above. Hole isn't finished yet, still a bit rough:
A picture is missing here. The wiring harness is pulled through the hole and the connector plate is fitted with two torx T20 screws.
Now the navigation arm can be clicked right into place:
Antenna is connected to the "hidden" wire. The antenna runs through the navigation:
The harness comes with fasteners which clicks right onto the dash:
The multi connector clicks right into place:
Fit the radio and re-assemble the dash .... aaaand TA-DAAAA:
Can't wait to go for a spin now!
Big thanks to b82ry, Stainless and gary02tdi
That's all for now - hope you can use the guide
Edited by: RasmusTJ
