41 - 60 of 153 Posts
Maybe if you install it well enough, they won't realise it was retro fitted!
Edited by: SiJ2000
That's only if they know... If you do a good job, they probably won't check/notice.
I retro fitted a VW MFD 2 DVD Sat Nav to a Golf Plus once and they upgraded the software on it at a service!
S
Yes because otherwise you can probably replace it if the manufacturer has not provided the cutting of holes in the dashboard. Otherwise, it is also the fact that if something happens to go down a dash or a peel color will certainly appreciate your intervention.
Edited by: gynox
RasmusTJ said:
448 ‚¬ without shipping costs (11 ‚¬ for Denmark) at www.teile-profis.de
I would be super happy if someone with Maps+More would take measurements of the hole in the dash for me, just to be sure I've made the right calculations
Thanks in advance!
Just requoting this to answer the question about cost. Good luck if you do it!
I was fiddling around in my take up today and found that my dash has a cap on it covering what seems to be a port for m&m. I didn't even bother looking before as it was a demo without even a spare wheel so knew m&m wasn't gonna be there but maybe it has. Dealer def didn't hand a unit over on purchase and didn't mention it. Am I right in thinking if there was no m&m wiring there's be no cap and no metal port and holes either side?
Help please wise forum!
Have you tried removingthe cap to even look..? Me thinks if its got the cover then it's M&M ready.
Some earlier cars had the cap but no wiring under it, the cap just clips out so you could take a look.....if there is wiring....bingo! You win a prize but if not, the retrofit would be relatively straightforward as the dash is ready for it.
Yup, you are all ready to go by the sound of it.......grab the unit and stalk and the wonderful world of maps and more awaits!
